Change the time
Oct 4th, 2007
Rather simple question but just want to be sure. I have two 9509's connected via a FCIP connection. The London one is 1 hour 30 minutes fast. The Europe 9509 is set to BST but correct for that timezone. Can I change the time on both switches and the timezone on the Europe switch without causing I/O problems?
Thanks.
Overall Rating: 4 (1 ratings)
inch Thu, 10/04/2007 - 22:21
  • Bronze, 100 points or more
G'day,
Time's on the switch have no relevance on data flows....
Cheers
Andrew
inch Thu, 10/04/2007 - 22:22
Forgot to add...
It might be worth keeping them set to UTC or something so it is easier to correlate debug information in the event of failures etc.
I know it can be a pain in the backside when you have multiple timezones trying to workout what log was what time was where :-)
dmcloon Thu, 10/04/2007 - 22:35
If you use tcp timestamps option you need synced clocks on each fcip peer, so NTP is recommended. Else the connection will fail. You can config variance tolerance. See config guide.
Trending Topics: Storage Networking
