7204VXR NPE card Gige throughput question
Oct 4th, 2007
Hi ,
We are installing a Gige-Gige solution for a customer using 7204VXR as CPE.
My sales engineers are saying that the NPE-G2 has a lower throughput than the NPE-G1 and that we should use the older card.
I find it hard to believe that cisco would introduce a card with worse throughput than it's predecessor , but am unable to find any documentation to back up my thoughts.
Does anyone have any ideas / proof /documentation ?
Many thanks in anticipation
Barry Firby
Overall Rating: 4 (1 ratings)
Jon Marshall Thu, 10/04/2007 - 04:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Barry
Not according to the data sheet for the NPE-G2. Look at the first row in the features table, the NPE-G2 pps performance.
http://www.cisco.com/en/US/products/hw/routers/ps341/products_data_sheet0900aecd8047177b.html
Might be worth verifying exactly what your sales engineer is referring to.
Jon
mci_FirbyJo Thu, 10/04/2007 - 04:37
Hi Jon ,
Thanks for the reply !
I saw that the NPE-G2 has twice the Mpps of the G1 .
They are reckoning that the actual throughput Gige - Gige of the NPE-G2 is only 200Mb , as opposed to the G1's 400Mb .
I have asked but not been given the doco to support these claims.
Cheers
Barry
slaptijack Fri, 11/02/2007 - 14:49
I'd sure like to see some documented evidence of this 200Mb throughput on the NPE-G2.
Joseph W. Doherty Thu, 10/04/2007 - 05:10
Agree with Jon, G2 should offer twice the performance of the G1. However, G2 only supported with 12.4 XD, SW and T release trains. This might be part of their concern.
