Adding h.323 gateway into Route grout
Oct 4th, 2007
At CCM 4.2 - is it possible to adding h.323 gateway into Route group/list? When I try it, at "Insert Route Group" page I dont see any of my installed (and working) gateways. Why?
shane.orr Thu, 10/04/2007 - 12:36
  • Silver, 250 points or more
you can only add h323 gateways to Route Group's Only not Route Lists. So the order I usually set things up is: Setup H323 Gateway, Setup Route Group containing Gateway, then setup Route List with containing the Route Group.
Now I have seen instances where the H323 Gateway will not show up as an available device for the Route Group if it is already used in a Route Pattern that sends calls directly to the Gateway instead of a route list.
In that case you have to temporarily send those calls in the Route Pattern to some arbitrary device then finish the setup of your gateway/route group/route list and then re-confgiure your route patterns to go to the route list rather than directly to the h323 gateway.
zsubar Thu, 10/04/2007 - 21:59
You are right....the gtwy are already used at Route patterns, and thats a reason....
Thanks a lot for your advice,
br
AJAZ NAWAZ Thu, 10/04/2007 - 21:02
This is a great document:
<http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/3_1_1/ccmsys/a03rp.html>
And this one too:
<http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed699.html#wp1311511>
Take a quick read and if you still need any help please let us know. We will be more than happy to assist.
Ajaz
