GLC-GE-100FX= compatibility with WS-X4448-GB-SFP
Oct 4th, 2007
I have one switch cisco 3550FX on distribute layer and i cant establish connect with my CORE Switch 4506 with de module WS-X4448-GB-SFP, i'm trying to use this module together with GLC-GE-100FX.
I already know that GLC-GE-100FX is compatible only on DSBU switches.
I was thinking if there's compatible IOS that enable the WS-X4448-GB-SFP to work with GLC-GE-100FX.
Tks
I have the SUP-V on my CAT4506.
ldesmasures Wed, 02/06/2013 - 01:29
Just a UP for this question/problem.
We encounter actually a problem with GLC-GE-100FX not recognized on 4507R+E with SUP7L-E in version 3.4.0SG (last version of IOS XE). We try to insert the GLC into a WS-X4448-GB-SFP but the module isn't recognized and we obtain the following message :
*Feb  6 01:53:26.631: %C4K_TRANSCEIVERMAN-3-INCOMPATIBLE: Port Gi1/3: New transceiver (speed 100Mbps) is incompatible with this module
Regarding all the release notes and compatibility matrix : all should be ok (firmware version, hardware, ...)
It's also imposible to use the speed command on the interface to force 100Mb/s speed...
Here is an output from : sh mod, sh int, ..
Switch#sh mod
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1    48  1000BaseX SFP                          WS-X4448-GB-SFP    xxxxx
3     6  Sup 7L-E 10GE (SFP+), 1000BaseX (SFP)  WS-X45-SUP7L-E     xxxx
M MAC addresses                    Hw  Fw           Sw               Status
1 30f7.0dbd.5bd0 to 30f7.0dbd.5bff 1.3                               Ok
3 6c20.56f8.2100 to 6c20.56f8.2105 1.1 15.0(1r)SG3  03.04.00.SG      Ok
Mod  Redundancy role     Operating mode      Redundancy status
3   Active Supervisor   RPR                 Active
Switch#   sh int statu | i 1/3
Gi1/3                        notconnect   1            full   1000 Unknown GBIC
Gi1/30                       notconnect   1            full   1000 No Gbic
Gi1/31                       notconnect   1            full   1000 No Gbic
Gi1/32                       notconnect   1            full   1000 No Gbic
Gi1/33                       notconnect   1            full   1000 No Gbic
Gi1/34                       notconnect   1            full   1000 No Gbic
Gi1/35                       notconnect   1            full   1000 No Gbic
Gi1/36                       notconnect   1            full   1000 No Gbic
Gi1/37                       notconnect   1            full   1000 No Gbic
Gi1/38                       notconnect   1            full   1000 No Gbic
Gi1/39                       notconnect   1            full   1000 1000BaseT
Switch#
Switch#sh int gi 1/3
GigabitEthernet1/3 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet Port, address is 30f7.0dbd.5bd2 (bia 30f7.0dbd.5bd2)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, link type is auto, media type is Unknown GBIC
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Switch#
Thanks for your help.
