automatic backup of catalyst 6500
Oct 4th, 2007
Hey!
i have a EEM script that backups the running conf when entering command "write memory" to ftp server.
How can i modify it, that it would'nt copy the file over and over. Instead it would make the conf file with diffrent name or date.
Any ideas?
amritpatek Wed, 10/10/2007 - 06:12
You can have the EEM script append the current data and time to file name whenever a "write memory" is given so that every time a file with a different name will be created. Another workaround would be to manually rename or move the file after entering command "write memory".
karblane1 Wed, 10/10/2007 - 22:57
Yep, at the moment cron changes the filename after it has been copied to backup server
guruprasadr Thu, 10/11/2007 - 02:38
HI karblane1,
This is Interesting.
Can you Please Provide me the Complete EEM Script you are Using.
Thanks in Advance for Help
Best Regards,
Guru Prasad R
Konstantin Dunaev Thu, 10/11/2007 - 03:10
hi,
we use a simple shel script, like this :
#!/bin/bash
umask 022
export DIR=/netmgmt
export ID=$$
export ROUTER=${1}
export DATEDIR=`/bin/date -I`
export COMMUNITY=${2}
export SNMPSET="/usr/bin/snmpset -m CISCO-CONFIG-COPY-MIB -v 2c -t 500"
export SNMPGET="/usr/bin/snmpget -m CISCO-CONFIG-COPY-MIB -v 2c -Ovque"
export SNMPWALK="/usr/bin/snmpwalk -m CISCO-CONFIG-COPY-MIB -v 2c"
export TFTPDIR=/tftpboot
#Write memory
echo "`date` $ROUTER:write memory" >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.2.${ID} i 1 >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.3.${ID} i 4 >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.4.${ID} i 3 >> $DIR/log_backup/log-${DATEDIR}
#Start writitng
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.14.${ID} i 1 >> $DIR/log_backup/log-${DATEDIR}
#Destroy MIB
OUT=`${SNMPGET} -c ${COMMUNITY} ${ROUTER} ccCopyState.${ID}`
while [ $OUT == 2 ]
do
done
${SNMPWALK} -c ${COMMUNITY} ${ROUTER} ccCopyState >> $DIR/log_backup/log-${DATEDIR}
if [ $OUT != 3 ]
then
echo -n "`date` ERROR: " >> $DIR/log_backup/log-${DATEDIR}
${SNMPWALK} -c ${COMMUNITY} ${ROUTER} ccCopyFailCause.${ID} >> $DIR/log_backup/log-${DATEDIR}
fi
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.14.${ID} i 6 >> $DIR/log_backup/log-${DATEDIR}
#copyto TFTP
/usr/bin/touch ${TFTPDIR}/${ROUTER}
/bin/chmod 777 ${TFTPDIR}/${ROUTER}
#Prepare MIB
echo "`date` $ROUTER:copy startup tftp" >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.4.${ID} i 1 >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.5.${ID} a "172.18.253.47" >> $DIR/log_backup/log-${DATEDIR}
${SNMPSET} -c ${COMMUNITY} ${ROUTER} .1.3.6.1.4.1.9.9.96.1.1.1.1.6.${ID} s "${TFTPDIR}/${ROUTER}" >> $DIR/log_backup/log-${DATEDIR}
#Start writitng
#Destroy MIB
while [ $OUT == 2 ]
do
sleep 1
done
if [ $OUT != 3 ]
then
fi
/bin/chmod 640 ${TFTPDIR}/${ROUTER}
/bin/cp -p ${TFTPDIR}/${ROUTER} $DIR/conf_backup/${DATEDIR}/${ROUTER}
/bin/rm ${TFTPDIR}/${ROUTER}
and every night at 00:01 we run these 2 scripts:
#!/bin/bash
DIR=/netmgmt
umask 022
export DATEDIR=`date -I`
mkdir $DIR/conf_backup/${DATEDIR}
#!/bin/sh
# Only keep config 120 days back
DIR=/netmgmt
find $DIR/conf_backup -ctime +120 -exec rm -rf {} \;
