Static Route --Need input
hassan_syed6
I have a very stupid question,
Let's say i have 2 routers. Router # A and Router # B. On Router # B I have a subnet defined on Fast Ethernet 0/0 ( 10.10.10.1/24) and there are some workstations sitting behind Fas0/0 ( 10.10.10.0/24). But now on the Fas0/1 i have defined ( 10.10.10.64/26).
Now on Router # A wants to communicate with Router # B subnets, so i have a static route saying " ip route 10.10.10.0 255.255.255.0 next hop will be Router # B connection right...So for /24 Router # A will go to # B to access workstations sitting on fas0/0 ( 10.10.10.0/24)
But at the same time for network 10.10.10.64/26 sitting behind fas0/1 can i also have a static route on Router # A "ip route 10.10.10.64/26 to access with the next hop on Router # B"
My problem is with static routes one with 10.10.10.0/24 this covers the range which is defined on Fas0/1 on Router # B. Will this static route work even though /24 covers the range of /26. Wouldn't router be confused with 2 static route one specific and the other one with /24...I hope i am clear where my confusion is...
Hassan...
Kevin Dorrell
Level 10
Level 10
Hassan ... let's get one thing sorted out ... there is no such thing as a stupid question. Occasionally there are stupid answers tho' ;-)
About 10.10.10.0/24 and 10.10.10.64/26, one single router will not allow you to do that. It will not accept overlapping ranges on the interfaces. However, what it will allow you is 10.10.10.0/24 on F0/0 and a static route to F0/1 for 10.10.10.64/26, provided F0/1 already has another IP address on it to enable IP.
I'm not sure I understand your addresing scheme and topology well, but I think I can answer your question. A more specific route will always have priority over a less specific one. So if you have 10.10.10.0/24 going to destination X, and 10.10.10.64/26 going to destination Y, then anything in 10.10.10.64/26 will go to destination Y, and anything in the rest of 10.10.10.0/24 will go to destination X.
Is that OK?
Kevin Dorrell
Luxembourg
5 Replies 5
Jon Marshall
Hassan
You shouldn't be able to configure this setup on Router B as the addressing overlaps so the router should complain when you try to address the second interface.
Jon
Kevin Dorrell
Level 10
Level 10
Is that OK?
Kevin Dorrell
Luxembourg
"Hassan ... let's get one thing sorted out ... there is no such thing as a stupid question. Occasionally there are stupid answers tho' ;-)"
Agree with Kevin on first point, no need to apologise as asking questions is how you learn.
Doubly agree with Kevin on second point about answers, just have a a look thru some of mine :)
Jon
Following is what i was looking for from Kevin
""""However, what it will allow you is 10.10.10.0/24 on F0/0 and a static route to F0/1 for 10.10.10.64/26, provided F0/1 already has another IP address on it to enable IP"""
I apologies, my explanation of issue was very incorrect.
Yes Second Interface has a different range ..but on the Fas0/1 I have a Firewall sitting which will have workstations with /26 ..so 2 static route one with /24 and the other one will /26 is doable right...
Hassan..
Right. In that case, don't send the 10.10.10.64/26 just to F0/1, but send it to the specific IP address of the firewall on F0/1. That way the router will not have to rely on the fairwall doing proxy ARP response (which, being a firewall, it probably won't do anyway).
Kevin Dorrell
Luxembourg
