Cat 6513 MSFC2 image upgade
Oct 4th, 2007
Will be perfoming an urgent IOS upgrade on a Cat 6513, from 12.1(19)E1 > 12.2.18SXD4.
Is it nessassry to upgrade the catOS on Sup2 too?
The current CatOS is 8.1(3).
Can the kind folks here point me the right direction. whitepapers?
Thax
Overall Rating: 3 (2 ratings)
chronix Thu, 10/04/2007 - 09:02
Hi Ankur,
Thank for the feedback.
No new line cards to be installed. Therefore i believe no CatOS upgrade is required to support the new image.
Thx.
glen.grant Thu, 10/04/2007 - 09:08
I would make sure you have adequate DRAM for that as 12.2.18 is considerably larger than the version you are currently running .
