Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919196members
1223314discussions
Community Activity
is Allegiant Air 24/7 ? {{{{{Help~line} #USA}}}}
How can I speak to an Allegiant Air representative fast?Talk to someone on Allegiant Air smoothly, give their dedicated support line a ring at + ퟏퟖퟎퟓ ퟑퟎퟗ ퟗퟑퟕퟕ . Take your time and listen carefully to the automated prompts, then share all the required...
How Do I Connect With People on Allegiant Air? {}
 How can I speak to an Allegiant Air representative fast?Talk to someone on Allegiant Air smoothly, give their dedicated support line a ring at + ퟏퟖퟎퟓ ퟑퟎퟗ ퟗퟑퟕퟕ . Take your time and listen carefully to the automated prompts, then share all the require...
Dhcp server with vlan's
Hello, I can't manage to give the connected PCs an ip through the dhcp server. My packet tracer + network design are attached. Have currently only started on the bottom part so it's only about the bottom PCs.Thanks in advance for the effort
TS40 by Level 1
  • 10 Views
  • 0 replies
Cisco ACS - 802.1x Radius Issue
I have a less then a dozen Cisco 3850 switches that I am working on.  I need to configure 802.1x authentication.  The issue is the switches are reaching out to Cisco ACS and I need to set up radius server to enable 802.1x.  The Cisco ACS I found out ...
John N by Level 1
  • 201 Views
  • 6 replies
WLC 9800-40 Disable IPv6
Hello  everybody,  sb know, how to disable IPv6 (CLI) on WLC9800-40? SW 17.4.1 IOS-XE Bengaluru. GUI Global Config do not works.  Thanks a lot.
CUIC - Total Talk Time
Hello all, Quick bit of background on this, the way our contact center currently works is that they have 1 line on their phones which they take both direct calls and calls via CSQ's. They have a few reports that they are using at the minute that incl...
CuCM doesn't reach our lab
Hi Joseph,I’m configuring our lab for testing on UCCE.I installed TSSOVA01 having IP address 192.168.204.20.I did a ping from TSS to CuCM 10.10.20.1 and I received packets.I did a ping from CuCM 10.10.20.1 using ssh to TSS and I didn’n receive any pa...
dada by Level 1
  • 2228 Views
  • 18 replies
Smart license
  PID : N540-24Z8Q2C-M IOS-XR : 7.8.2 I want to know about smart licenses. The command is enable, but when I apply the command below, it behaves as if the license is off. RP/0/RP0/CPU0:PE-02#show run | inc licWed Mar 27 10:13:34.359 KSTBuilding confi...
9166 clients not connecting at 5 GHz
9800-80 pair running 17.9.4a and APSP8 (upgraded about a month ago). Upon investigating after slowness/connection complaints from the professor of a 150-seat lecture hall where 9166s are installed, I realized that every single client in the room was ...
