Richard Burts Thu, 10/04/2007 - 07:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Cindy
The ip classless command is used in IOS to enable forwarding to supernet addresses. In practical terms it usually controls whether the device can forward to the default route a packet whose destination address is for a subnet that is not in the routing table but another subnet of that network is in the routing table.
That makes a lot more sense on a layer 3 device which will have a more sophisticated routing table. On a layer 2 switch like the 2950 it would seem to make less sense. My guess is that it shows up to maintain compatibility in IOS structures.
Rick
cindylee27 Thu, 10/04/2007 - 08:50
Hi Rick,
Thanks for the explaination but is there any eg: for the supernet addresses u are referring to differentiate ip classless and ip classful ? :)
Richard Burts Thu, 10/04/2007 - 09:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Cindy
I do not understand the follow up question that you are asking. Can you help me understand better what you are looking for?
Rick
