PLAR / Hotdial with IP Phones with only one DN
Oct 4th, 2007
I would like to know if its possible to configure a line in ip phone that if i didn't dial a number in 5 seconds an emergency number are dialed automaticaly.
I know how to configure PLAR but this didn't give me a chance to dial another number before.
Best Regards
If you want a phone to dial a specific number as soon as it goes of hook, you have to create a blank translation pattern, with the called party transformation mask as the number you want dialed. Basically how I did it was to create a special partition for this translation pattern because if you have more than one they have to be in unique partitions. Then create a specific CSS with this partition in it and all of the other neseccary partitions and apply that to the phone. When the phone goes off-hook it immediately matches that blank pattern and calls the number you specified.
Hope that helps
[email protected]
