10-04-2007 07:11 AM - edited 03-18-2019 07:54 PM
I was wondering if someone could help me find documenation on applying MS hotfixes, especially MS KB 911829 and whether Cisco has blessed it with Unity.
Solved! Go to Solution.
10-04-2007 09:25 AM
Hi -
Are you already running Exchange 2003 SP2 with Unity 4.0(4)? This version is a requirement for the KB911829. If you are not running Exchange 2003 SP2 yet, please read this article - http://www.cisco.com/en/US/customer/products/sw/voicesw/ps2237/products_field_notice09186a00807dcf40.shtml
You will need to adjust your Send As permissions. There was also a new permissions wizard version that was needed for Exchange 2003 SP1 to maintain voice message functionality - http://www.cisco.com/en/US/customer/products/sw/voicesw/ps2237/products_field_notice09186a008024d72f.shtml
Also, Cisco now has its own process for applying security or other hotfixes to its applicable voice servers, which include Unity. Here is the new link - http://www.cisco.com/en/US/docs/voice_ip_comm/unity/updates/wizard/cuupwz.html
I did not see KB911829 in the list, so you might want to check with TAC on this. In any case, I would recommend breaking your Unity server's mirror set and ensuring you have a good backup for recovery before applying any update to your server.
Hope this helps! Ginger
10-04-2007 09:25 AM
Hi -
