How to upgrade IOS
Answered Question
Oct 4th, 2007
Hi, my WS-C2970G-24T-E has very old IOS software and is acting a bit strange lately. Spontanious reboots etc. Before completely writing it off, I would like to perform an IOS upgrade to see if that fixes problems.
The switch is running IOS version 12.1(19)EA1c from SW image C2970-I6L2-M.
It has enough memory (128 and 512) to run the latest 12.2 version. I downloaded c2970-lanbase-tar.122-40.SE.tar.
I currently only have a serial cable attached.
How do I proceed with the upgrade?
Correct Answer by uubozou11 about 9 years 3 months ago
There are a few articles on Cisco site and also techrepublics....
http://blogs.techrepublic.com.com/networking/?p=337
Overall Rating: 5 (2 ratings)
aanthonisse Fri, 10/05/2007 - 01:25
Thanks, worked like a charm.
I used TFTP32 from Ph. Jounin.
First I made a backup of the current software and configuration with
copy flash:c2970-i6l2-mz.121-19.EA1c/c2970-i6l2-mz.121-19.EA1c.bin tftp
and
copy flash:config.text tftp
then i downloaded the new software with
archive download-sw tftp://172.28.10.3/c2970-lanbase-tar.122-40.SE.tar
System prompted with several easy to answer options and then reported a syuccesfull upgrade.
I reloaded the switch and it worked with the new software.
Thanks again,
Arjan
