stack with 3750-48TS
Oct 4th, 2007
Hi:
Should I connect the port-1 of the swith-1 to the port-2 of the swith-2 to enable the stack?
What happen if I use the port 1 in both switches? It should work, right?
Regards.
glen.grant Thu, 10/04/2007 - 09:14
  • Purple, 4500 points or more
Yes port 1 to port 2 on the 2nd switch . If you add a 3rd , it would go 1 to 2 on the third and then you would run port 1 on the 3rd switch to port 2 on the first switch to make it redundant.
