7931G incoming call configuration button
Oct 4th, 2007
Hi Dear Experts,
can you help me?
I have a problem to understand a possible configuration in a system with 2811 CCME and about 20 7931G IP phone.
When there is an incoming call now it arrives on botton 20 (line 100 = Segreteria) and it flashing amber color. A secretary answers and on she phone botton 20 change color in green fixed and on the others phones botton 20 turns off. When another incoming call arrives botton 20 flashing amber again etc...for maximun 4 incoming calls.
The problem is that incoming calls arrive on 100 line and the single secretary lines 103, 104, 105 and 106 are free and when a secretary answers to a call her line botton is turned off but instead of she is busy!!!
The manager don't see she is busy and he tries to call she but she are into a call and she cannot answer!!!
Question: Is it possible to monitor line state of 103, 104, 105 and 106 line when they has busy after answer on a incoming call too?
Router 2811 firmware: 12.4.15T1
IP Phone 7931G firmware: SCCP31.8-2-2SR1S.
Configuration:
tftp-server flash:apps31.8-2-2ES1.sbn
tftp-server flash:cnu31.8-2-2ES1.sbn
tftp-server flash:cvm31sccp.8-2-2ES1.sbn
tftp-server flash:dsp31.8-2-2ES1.sbn
tftp-server flash:jar31sccp.8-2-2ES1.sbn
tftp-server flash:SCCP31.8-2-2SR1S.loads
tftp-server flash:term31.default.loads
num-exp 451234567 100
telephony-service
load 7931 SCCP31.8-2-2SR1S
max-ephones 35
max-dn 60
ip source-address 192.168.168.4 port 2000
timeouts interdigit 7
url directories http://192.168.168.2/fw/apps/Speedy/xml/directory.asp
url authentication http://192.168.168.2/fw/authenticate.asp
user-locale IT
network-locale IT
time-format 24
date-format dd-mm-yy
max-conferences 12 gain -6
call-forward pattern .T
moh music-on-hold.au
web admin system name admin password router
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
ephone-dn 3 dual-line
number 103
pickup-group 100
name Antonella I.
no huntstop
transfer-mode consult
ephone-dn 4 dual-line
number 104
pickup-group 100
name Daniela P.
no huntstop
ephone-dn 5 dual-line
number 105
pickup-group 100
name Alice C.
no huntstop
ephone-dn 6 dual-line
number 106
pickup-group 100
name Sala Server
no huntstop
ephone-dn 60 dual-line
number 100
pickup-group 100
name Segreteria
no huntstop
ephone 3
mac-address 001B.538E.F50A
ephone-template 15
type 7931
button 1:3 2m1 3m2 4m4
button 5m5 6m7 7m8 8m9
button 9m10 10m11 11m12 12m13
button 13m15 14m16 15m17 16m18
button 17m19 18m20 19m23 20:60
ephone 4
mac-address 001B.538E.F5DD
ephone-template 15
type 7931
button 1:4 2m1 3m2 4m3
ephone 5
mac-address 001B.538E.F37D
ephone-template 15
type 7931
button 1:5 2m1 3m2 4m3
button 5m4 6m7 7m8 8m9
ephone 6
mac-address 001B.D46C.3E92
ephone-template 15
type 7931
button 1:6 2m1 3m2 4m3
button 5m4 6m5 7m7 8m8
button 9m9 10m10 11m11 12m12
button 13m13 14m15 15m16 16m17
button 17m18 18m19 19m20 20:60
Thank you for best support
Kind Regards
Adriana
Rob Huffman Thu, 10/04/2007 - 10:31
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Adriana,
I think this is because this DN (103) is set up as dual-line you need to add the following. Have a look;
The following example creates an ephone-dn with the number 103 in dual-line mode. The no huntstop command allows calls to continue to hunt to other ephone-dns if this one is busy or does not answer. The huntstop channel command disables call hunting to the second channel of this ephone-dn if the first channel is busy or does not answer.
Router(config)# ephone-dn 10 dual-line
Router(config-ephone-dn)# number 103
Router(config-ephone-dn)# no huntstop
Router(config-ephone-dn)# huntstop channel
Router(config-ephone-dn)# exit
From this CME doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a0080611350.html#wp1056194
Hope this helps!
Rob
aferroglia Tue, 10/09/2007 - 04:53
Thank you Rob for best help,
but probably I didn't had explain correctly my question;
now I have to have four 7391G that ring simultaneously when there is one or more incoming calls and I have to see flash amber lamp of incoming line (100) = button 20 on everyone phone (3, 4 ,5 and 6). When one secretary answers to call, I would see the button equivalent to number of secretary to become red fixed and botton 20 (line 100) turn off. In this moment, all people of office would can to see that she is busy!
etc. etc for second, third and fourth incoming call for every segretary to answer to incoming call.
I have tried to modify configuration add command "secondary" line 100 to primary phone line, (see on the bottom), but yes, it works, but only one phone ring random... one time 103, one time 103, one time 102, one time 104 and so on...but not all simultaneously !!!
Is it possible to do it?
telephony-service
max-ephones 35
max-dn 60
user-locale IT
network-locale IT
time-zone 23
time-format 24
dn-webedit
time-webedit
transfer-pattern .T
log password cisco
secondary-dialtone 0
xmltest
create cnf-files version-stamp 7960 Oct 03 2007 18:32:48
ephone-template 15
button-layout 7931 2
number 103 secondary 100
pickup-group 100
name Antonella I.
huntstop channel
no huntstop
number 104 secondary 100
pickup-group 100
name Daniela P.
huntstop channel
no huntstop
number 105 secondary 100
pickup-group 100
name Alice C.
huntstop channel
no huntstop
number 106 secondary 100
pickup-group 100
name Sala Server
huntstop channel
no huntstop
ephone 3
ephone-template 15
type 7931
ephone 4
ephone-template 15
type 7931
ephone 5
ephone-template 15
type 7931
ephone 6
ephone-template 15
type 7931
Please do you understand why? Is it a system bug???
Can you help me?
Thank you
Kind Reagards
Adriana
paolo bevilacqua Tue, 10/09/2007 - 05:12
  • Hall of Fame,
    Founding Member
Adriana,
what you are seeing is normal. You are using shared line to receive calls, that has many disadvantages. For one, is that subsequent calls coming on the shared line, will be presented only to the phone that has taken the first call.
Second, you won't see the lighted button correctly for shared lines, because when you monitor a shared line with the 'm' separator, it will go red no matter who has actually taken the call.
I suggest that you set an ephone-hunt for this, else with the shared line you have to live with the limitations. There are way to configure around them, but confirm with the customer first if a regualt hunt woldnt be better.
aferroglia Tue, 10/09/2007 - 08:39
Hi Paolo,
thank you for answer, but I'm reading on cisco doc:"Cisco unified Communications Manager Express System Administrator Guide" that about ephone-hunt Cisco writes for parallel hunt have possible use them only with SIP phone configuration and not with SCCP phone as I'm using now. Manual writes for SCPP phone configuration to use shared line.
I ask you if is it possible change use of phone from SCCP to SIP or are there any problems?
Please could you do an example about SIP parallel hunt?
Kind Regards
Adriana
