Catalyst 4006 Cat OS to IOS
Oct 4th, 2007
Hello:
Just wondering if this is even possible. The chassis in question has a WS-X4013 sup in it, 64MB of DRAM and 16MB of flash. Any more detail needed, please let me know. TIA for any guidance.
Brad Olson
Overall Rating: 5 (2 ratings)
glen.grant Thu, 10/04/2007 - 09:09
The quick answer is no you cannot upgrade that to IOS , catos only. You need a Sup IIplus to have IOS and that comes with it from the factory.
ankbhasi Thu, 10/04/2007 - 09:16
Hi Brad,
This facility is not available for cat4k switches like you have on Cat6k switches. Cat4k sups will either run CATOS or will run IOS.
So sup 1 and sup 2 will only run and support CATOS and sup 2+,3,4,5 will only run IOS.
Ankur
*Pls rate all helpfull post
brad_olson Thu, 10/04/2007 - 09:18
Thanks all. The search function wasn't working for me at the time of my post. I found exxactly what you both are saying. Thank you, much appreciated.
