Anyway to update the interface desc automatically?
Answered Question
Oct 4th, 2007
Hi Experts,
I know this is probably a silly question but I am just trying..:)
Well, I am trying to put description to all the 3750 Switches Interface with a list I have gotten in excel file, now question is .. Is there any method to pop over those info to the 3750 switch? :)
Correct Answer by Jon Marshall about 9 years 6 months ago
Hi Cindy
I'm assuming the descriptions are different per interface.
The easiest way would to be export your excel spreadsheet into a text file and format it so that it turns out
interface fa0/1
desc "jdsjdd"
interface fa0/2
desc "xqqaqa"
etc...
then just cut and paste from config mode on switch.
But obviously without knowing the format of the data in the excel it is difficult to say whether it is worth the effort.
You can also write programs/scripts to do this but again you would need the data to be in the right format to input into the script and if this is quite a rare thing to it probably isn't worth the time and effort.
Other than that i'm afraid it's one by one.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Thu, 10/04/2007 - 09:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Cindy
interface fa0/1
desc "jdsjdd"
interface fa0/2
desc "xqqaqa"
etc...
Jon
cindylee27 Fri, 10/05/2007 - 02:52
Thanks Jon for your time on this small "little" question..:) Appreciate that..
Yeah, thought of the method of text file too..Guess will go with this..
Thanks again.
