Ciscoworks Software Management
Oct 4th, 2007
Does anybody knows the steps involved on Ciscowoks Software Management when upgrading and IOS?? Does the old IOS is erase and then the new IOS loaded? or Not erase until the newer version is in?
Or how does it work?
David Stanford Fri, 10/05/2007 - 07:45
It depends on the parameters you select when running the job. You can have it erase first, or you can just add it and add boot parameters.
