Unity Phone View doesnt work with CCM4.13
Oct 4th, 2007
trying to setup Unity 5.0 Phone view with CCM 4.13. Get an error with SelectCmDevice OpenRequest Fail. Testing with http://ccm-ip/ccmcip/authenticate.jsp.
This JSP file is not on my ccm 4.13 server. Its only on a ccm5.x server.
In the integration I am selecting CCM4.13 integration. The passwords and user accounts are correct.
Any ideas ?
jrezab Mon, 10/08/2007 - 07:26
Yes I have gone through that guide. That is one of the issues I am raising. The guide indicates to test with authenticate.jsp file. In Call Manager 4.13, there isnt a JSP file, its an .ASP file.
I have a TAC case open since last week. They are still trying to figure it out.
fischerd Fri, 10/12/2007 - 13:16
I have looked into this and you are correct that CCM 4.1(3) does not have authenticate.jsp. This is an error in the troubleshooting doc. The document should have separate sections for 4.x and 5.x+ for this troubleshooting step. Using authenticate.asp is the correct thing to do in that step. Sorry about the confusion.
Jason Aarons Tue, 01/27/2009 - 08:17
  • Bronze, 100 points or more
Did you ever get a resolution for this? I'm hitting same issue with Unity 5.0(1) Phone View and CallManager 4.1(3)SR6. I suspect it has something to do with MLA, and this customer deleted CCMAdministrator when they setup MLA. I am using a user who under MLA is in the SuperUserGroup but still failing.
10:58:04 Attempting to connect to a CUCM/CCM Server and retrieve its device list.
10:58:04
10:58:04 Trying to connect to 10.75.250.102:80
10:58:04 Connect succeeded - Trying to retrieve devices from 10.75.250.102
10:58:04 Attempting to retrieve the list of phone devices
10:58:04 from CUCM/CCM. This may take a moment...
10:58:07 Successfully retrieved the list of
10:58:07 3490 phone devices from CUCM/CCM..
10:58:07 Retrieving registration status and device info for
10:58:07 device list items 1 to 200 of 3490.
10:58:08 Error: Phone View - WinHttpReceiveResponse failed in OpenRequest
10:58:08 Phone View - SelectCmDevice OpenRequest failed
10:58:08 Error: Phone View - RetrieveDevices failed to call SelectCmDevice
10:58:08 Failed to retrieve devices from 10.75.250.102 - will try next server (if any)
