Limiting amount of login on cisco router
Oct 4th, 2007
Anybody has a clue of command I can issue to limit the amount of logins on a cisco router with IOS 12.2 .Am trying to limit lets say if a user is login into the router it will limit that user from openning up another session concurrent.I saw doing it via using a timeout but not want I want.Any help
Kevin Dorrell Thu, 10/04/2007 - 13:57
For a particular user, username user max-links n.
For an overall limit, the router will limit when you run out of vty slot, usually 15, but on some versions 5.
Kevin Dorrell
Luxembourg
paul.matthews Fri, 10/05/2007 - 01:04
I suspect that if you want to allow three people to login concurrently, but each only once, you will need to investigate something ike Radius and Ciscosecure ACS to handle that.
Paul.
