Rajesh Revuru Thu, 10/04/2007 - 12:16
  • Silver, 250 points or more
Please check "Call Waiting timer" under the service parameters
rgoodwin7399 Thu, 10/04/2007 - 12:24
Thank you for the reply. I am trying to find that paramater and not able to. What page is it on?
Rajesh Revuru Thu, 10/04/2007 - 12:41
Apologies.. that parameter is only available until 3.3. For new 4.x they have introduced busy trigger.
I am not sure how to change the beep timer on call-waiting.
rgoodwin7399 Thu, 10/04/2007 - 12:43
Ok. Well thank you for the replies anyway. From what I have seen it doesn't look like you can change the beep-timer in 4.x.
Rob Huffman Thu, 10/04/2007 - 13:15
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rachel,
Have you tried this setting on the Directory Number Configuration Page>Line Settings for this Device>Ring Setting (Phone Active)
This can toggle between Ring Once and Ring (which continues to Ring)
Hope this helps!
Rob
rgoodwin7399 Thu, 10/04/2007 - 13:44
That gets me an audible ring which is nice but what I am really trying to do is make it beep more than once on a second incoming call. Is that possible with CCM 4.1.3? The obvious drawback to the "ring" setting is that it is loud for the user and whoever they might be on the phone with.
