VPN 6.3 IP Restrictions
Oct 4th, 2007
We have a PIX successfully running VPN (I just inherited this network so I am not sure what all is here yet) and we want to restrict which external IPs can access VPN. What is the best method to do this? See my config below (With obvious parts removed or Xd out)
global (outside) 10 interface
global (dmz) 10 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 10 0 0
nat (dmz) 0 access-list dmz_outbound_nat0_acl
static (inside,dmz) netmask 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group dmz_access_in in interface dmz
route outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa authentication ssh console LOCAL
ntp server xxx source outside
http server enable
http inside
http inside
http inside
snmp-server host inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
tftp-server inside /pix/startup-config-20041029
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication LOCAL
crypto map outside_map interface outside
isakmp enable outside
isakmp nat-traversal 20
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup XX1es dns-server
vpngroup XX1es wins-server
vpngroup XX1es default-domain XXX
vpngroup XX1es idle-time 1800
vpngroup XX1es password ********
management-access inside
username XXX password xxx
