Problems configuring firewall
Oct 4th, 2007
I have a 1721 cisco router with the ethernet port and a lan wic.
The router has 192.168.156.252 ip configured. We have configured with 192.168.156.25 ip address a router connected by my isp.This router has been configured with this ip, we can not change it or enter to administer the software.
I tried to connect a lan wire from this router(teldat) to the 1721 ethenet wic port and use the IOS firewall to filter certain ports.. protocols and more...
Using SDM 2.4.1 I tried to configure the firewall but the wizard says that they have the same lan ip and it is impossible.
what can I do?
best regards
whisperwind Fri, 10/05/2007 - 10:26
Either subnet the two interfaces so they are logically different or change one of them to a new subnet.
whisperwind Sun, 10/07/2007 - 05:57
I will try, put a different network on the interface so they do not overlap, you can either use subnetting or something like
10.0.0.1 255.255.255.0
I recommend you google subnetting and read up on it.
