Port Forwarding
Oct 4th, 2007
Can someone write commands for me to do the following:
I need to get my NAT from Moderate to Open.
To do this I need the following Ports Forwarded to the Following Ip address:
TCP: 88
TCP: 3074
UDP: 3074
IP address 192.168.1.99
I have a dynamic outside IP address (Time Warner Cable)
esupport Fri, 10/12/2007 - 03:00
I have assumed that you have named your inside interface Moderate and your outside interface Open and that 192.168.1.99 sits on the inside of your network i.e. behind the Moderate interface. Based on this the commands on the PIX will look something like this.
static (Moderate,Open) tcp interface 88 192.168.1.99 88 netmask 255.255.255.255
static (Moderate,Open) tcp interface 3074 192.168.1.99 3074 netmask 255.255.255.255
static (Moderate,Open) udp interface 3074 192.168.1.99 3074 netmask 255.255.255.255
Hope this is helpful.
Thanks.
readymixed1 Fri, 10/12/2007 - 05:34
Thanks problem solved below is the solution:
static (inside,outside) tcp interface 3074 192.168.1.99 3074 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 3074 192.168.1.99 3074 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 88 192.168.1.99 88 netmask 255.255.255.255 0 0
access-list outside permit tcp any interface outside eq 3074
access-list outside permit udp any interface outside eq 3074
access-list outside permit udp any interface outside eq 88
