OSPF on a NATTED subnet
Oct 4th, 2007
We implemented OSPF across a Sprint MPLS network. One of the sites we recently acquired has overlapping addresses so we have a static nat command mapping their internal subnet to another subnet. I need this NATTED address to be distributed via OSPF.
I have the following
interface FastEthernet0/0
ip address 192.168.1.250 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
ip address 172.20.174.198 255.255.255.252
ip nat outside
service-module t1 timeslots 1-4
router ospf 1
router-id 172.20.174.198
log-adjacency-changes
redistribute static subnets
passive-interface FastEthernet0/0
network 172.20.174.196 0.0.0.3 area 0
network 192.168.41.0 0.0.0.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 192.168.41.0 255.255.255.0 Null0
ip route 192.168.200.0 255.255.255.0 192.168.1.1
ip nat inside source static network 192.168.1.0 192.168.41.0 /24
For some reason 192.168.41.0 isn't being distributed.
As a test I tried this
interface loopback1
ip address 192.168.41.1 255.255.255.0
and this actually worked.
Why doesn't it work without it?
I have redistribute statis set under OSPF and I have a static route to 192.168.41.0 pointing to Null0.
Denny
sundar.palaniappan Thu, 10/04/2007 - 15:36
  • Green, 3000 points or more
Denny,
It should work with your configuration. When you don't have the loopback 1 interface created what does 'show ip route 192.168.41.0' shows up as. If it shows up as a static null route then the redistribution should work.
Sundar
dennylester Thu, 10/04/2007 - 15:44
Here is what it shows
Known via "static", distance 1, metric 0 (connected)
Redistributing via ospf 1
Advertised by ospf 1 subnets
Routing Descriptor Blocks:
* directly connected, via Null0
Route metric is 0, traffic share count is 1
This has me stumped.
Denny
sundar.palaniappan Thu, 10/04/2007 - 16:05
I quickly tested this in my lab and it works just fine. Do you have any distribute list (inbound) applied on the router that should be learning the route that's filtering this route. Does the recipient router learn the other static routes via OSPF?
If possible post a sanitized copy of the full configuration from both routers.
R2#show run | b router ospf
router ospf 1
network 172.30.1.12 0.0.0.0 area 0
R2#show ip route 200.200.200.0
Routing entry for 200.200.200.0/24
R1#show ip route ospf
O E2 200.200.200.0/24 [110/20] via 172.30.1.12, 00:29:47, Ethernet0/0
R1#show ip route 200.200.200.0
Known via "ospf 1", distance 110, metric 20, type extern 2, forward metric 10
Last update from 172.30.1.12 on Ethernet0/0, 00:29:54 ago
* 172.30.1.12, from 100.100.100.1, 00:29:54 ago, via Ethernet0/0
Route metric is 20, traffic share count is 1
Sundar
dennylester Thu, 10/04/2007 - 20:35
Hi Sundar,
Thank you for replying.
I'm out of the office until Monday, so I won't be able to post the configs until then.
Do you really think it could be the other side?
I thought I had ruled out the Sprint MPLS Network and the host site when the Remote Site successfully distributed the subnet after applying an IP address in that subnet to the loopback interface.
The moment I removed the subnet from the loopback interface the route was removed.
Perhaps I am missing something.
I'm going to check and see if the version IOS could be the problem. I believe it is 12.4(1c)
