Harold Ritter Thu, 10/04/2007 - 14:54
It is certainly possible as long as you can configure the interface with logical subinterface such dot1q, frame-relay. Each subinterface would in turn fall into a specific VRF.
royalblues Fri, 10/05/2007 - 00:48
As harold pointed out, each logical interface can be a part of a different interface
It is not possible for a single interface though to be part of more than one VRF forwarding instance.
if you are just talking about route tables, you can always import the routes from another VRF which would be mean you have more than one routing table available :-)
Narayan
guruprasadr Fri, 10/05/2007 - 02:45
HI Narayan / Hritter,
Please provide me the sample end - to - end VRF Configuration with Example setup and Configuration.
I have a challenge of VRF implementation still pending in my JOB.
Pls Help....
Best Regards,
Guru Prasad R
royalblues Fri, 10/05/2007 - 03:16
Attched configs might help which i did in my lab
There are no P routers invoved in this as i had very limited routers available to test but it should be good to get a idea
Anyway you should be getting plenty of these in CCO
Narayan
