10-04-2007 03:55 PM - edited 03-05-2019 06:54 PM
I have setup a lab with 2 routers with T1 WICs. I was wondering if I could configure the T1s with freme-relay, would that work? I have tried them with PPP and that worked fine.
Thanks in advance,
10-04-2007 04:10 PM
Yes you can. Here's the link.
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a0080094a3b.shtml
Sundar
10-05-2007 05:50 AM
Sadik
Sundar is quite correct that you can configure 2 routers with back to back serial connection to use frame relay encapsulation. Be aware that without a device acting as a frame relay switch that it will not act entirely as real frame relay does. For example there will be no LMI in a back to back frame relay configuration. There is also no processing for DE frames or for FECN or BECN.
Rick
10-05-2007 08:06 AM
Thaks to both of you. That helped!
sK
