Cisco 500 Series - Port Security
Answered Question
Oct 4th, 2007
Does anybody know how the port security works with Cisco 500 Series. I can not restrict one mac-address to one port manually so, how does it works?
Correct Answer by Jagdeep Gambhir about 9 years 9 months ago
Depending on the Smartport Role you assign the CE500 design has a port security. For instance the port role Access Point will only allow a maximum of 30 MAC addresses only and the Ip Phone + Desktop will allow only 3 MAC addresses.
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K43299660
So by configuring smartport, you are also configuring port security.
~JG
Please rate helpful posts
Overall Rating: 5 (1 ratings)
muca Thu, 10/04/2007 - 17:31
What I mean is that I can not specify the maximum number of devices right? And just one device is allowed on the port
Correct Answer
Jagdeep Gambhir Fri, 10/05/2007 - 05:38
  • Red, 2250 points or more
~JG
muca Fri, 10/05/2007 - 13:55
Thank you very much. That's the exactly information I was looking for.
