MGCP FXO Port for paging system
Oct 4th, 2007
  • Silver, 250 points or more
Does anyone know how in CCM 5.1(2) you can set up a MGCP controlled port to just go offhook and not send the digits dialed?
In CCM 4.x, setting up a route pattern such as 1234. with PreDot digit strip worked and port went offhook and no digits were sent. Tried the same in CCM 5.x and get unknown number and reorder tone. When I change the route pattern to just 1234 without the dot it connects to the port but also sends 1234 which results in reorder tone back from the paging system. Is there another way to just get a FXO port to go offhook with MGCP and not send digits out with MGCP?
Got it working by doing H323 for now, but would like to stick with MGCP since everything else is MGCP here.
Marcos Assakawa Wed, 10/10/2007 - 06:11
  • Cisco Employee,
It seems that you are hitting this bug CSCsi19351.
Make sure that you have the CallManager version that has the bug integrated.
