configuration backup on remote location....
Overall Rating: 4 (1 ratings)
David Stanford Fri, 10/05/2007 - 06:08
About the best thing you could do would be to take a backup of the shadow directory. You can change the archive location, but may have some challenges sending it to a remote can try it, not sure if it is supported:
RME - Admin - Config Mgmt - Archive Mgmt - Archive Settings...change the location here if it is a mapped drive or partition
The only place where configs are stored with hostname/IP is the shadow directory:
On Solaris,
On Windows,
