CNR cnr_exim abort
Oct 4th, 2007
Actually, I'm trying to get a print out of all my scopes and policies in a readable format. I'm running CNR 6.2.2 on a Sun server running Solaris 9. I used the cnr_exim command and when I ran it I got the following:
[3] cnr_exim -e cnrdata
user: admin
password:
*** 'aheap.cpp':1053 ASSERTION 'AABORT requested' failed
Abort
If I run the command with a -x to get the data in raw format, it works just fine - or at least I think it does, as I can't read it.
Any ideas?
David Stanford Fri, 10/05/2007 - 07:05
Looks like its similar to bug CSCsh17797
Symptom:
The cnr_exim utility can abort due to memory corruption when exporting
Network Regustrar data in text format.
Workaround:
Export data in s-expression format using the -t option.
