Problems with BARS 4.0.12
Answered Question
Oct 5th, 2007
Hi.. I have a CM ver 4.1(3)sr4d with BARS Version 4.0.12000, and I receive some errors in the Backup Task Log Scheduled or Manual Backup (Log File Attached)I make this tests:
Sincronize all passwords with AdminUtility.exe Tool and everything its ok,
The password of the username BackAdmin and Administrator is the same, and both have full access permisions
I reinstall the application some many times but I recieve the same error in log
Can Every Body Help Me Please!!!!!
Thx....
Correct Answer by irisrios about 9 years 8 months ago
Try reloading the CMPUB.I have seen such an issue with BARS only when the Remote Registry Service is stopped. That is why it fails with " Failed to backup CCM Registry " since the service necessary for registry access was stopped or not functioning
even though it was started i.e, service was hung without processing requests. Hence a reboot of the CCMPUB stopped and started this service cleanly and hence the backup now works.
Overall Rating: 5 (1 ratings)
Correct Answer
irisrios Thu, 10/11/2007 - 08:34
  • Silver, 250 points or more
mmunoz-20 Sat, 10/13/2007 - 14:18
Oh thanks.. I check the Remote Registry Service in Control Panel - Administrative Tools - Services, and was stopped (Manual Start), I change it to Automatic Start and put service in running state manually, and everything works fine...
[03:15:43 PM] Backup operation completed successfully.
Tanks again....
