10-05-2007 02:40 AM - edited 03-05-2019 06:54 PM
Hi all,
I've set up a mrm test as described below:
Test Manager:
Manager:prueba/10.0.0.14 is running, expire:23:39:19
Beacon interval/holdtime/ttl:5/86400/32
Group:239.192.7.76, UDP port test-packet/status-report:16384/65535
Test senders:
10.0.0.15 /Ack
Test receivers:
10.12.70.189 /Ack 10.12.70.190 /Ack
Test receivers are getting multicast test packet:
deb udp
ct 5 12:01:33 CET: UDP: rcvd src=10.0.0.15(16384), dst=239.192.7.76(16384), length=24
Oct 5 12:01:33 CET: UDP: rcvd src=10.0.0.15(16384), dst=239.192.7.76(16384), length=24
And, of course, port 16384 is listening:
Prueba2#sh ip sockets
Proto Remote Port Local Port In Out Stat TTY OutputIF
17 --listen-- 10.12.70.249 1985 0 0 1 0
17 10.0.0.194 514 10.1.22.5 51800 0 0 10 0
17 10.0.0.178 514 10.1.22.5 52917 0 0 10 0
17 0.0.0.0 0 10.12.70.249 67 0 0 2211 0
88 --listen-- 10.12.70.249 100 0 0 0 0
17 --listen-- 10.12.70.249 123 0 0 1 0
17 10.0.0.90 39728 10.12.70.249 161 0 0 1 0
17 --listen-- 10.12.70.249 162 0 0 11 0
17 --listen-- 10.12.70.249 56715 0 0 11 0
17 --listen-- 224.0.1.40 496 0 0 61 0
17 --listen-- 10.1.22.5 679 0 0 1 66
17 --listen-- 10.12.70.189 16384 0 0 1 0
So, it seems to work fine but the manager receive status report packet with 100% lost packets.
Oct 5 09:58:35.846: IP MRM status report -- Test:visualtrader Receiver:10.12.70.190
Oct 5 09:58:35.846: Sender:10.0.0.15 Pkt Loss:200(100%) Ehsr:0
Oct 5 09:58:36.814: IP MRM status report -- Test:prueba
Receiver:10.12.70.189
Oct 5 09:58:36.814: Sender:10.0.0.15 Pkt Loss:200(100%) Ehsr:0
Oct 5 09:58:36.850: IP MRM status report -- Test:prueba
Oct 5 09:58:36.850: Sender:10.0.0.15 Pkt Loss:200(100%) Ehsr:0
Oct 5 09:58:37.818: IP MRM status report -- Test:prueba Receiver:10.12.70.189
Oct 5 09:58:37.818: Sender:10.0.0.15 Pkt Loss:200(100%) Ehsr:0
Oct 5 09:58:37.854: IP MRM status report -- Test:prueba Receiver:10.12.70.190
Oct 5 09:58:37.858: Sender:10.0.0.15 Pkt Loss:200(100%) Ehsr:0
Oct 5 09:58:38.814: IP MRM status report -- Test:prueba Receiver:10.12.70.189
Oct 5 09:58:38.814: Sender:10.0.0.15 Pkt Loss:200(100%) Ehsr:0
Oct 5 09:58:38.858: IP MRM status report -- Test:prueba Receiver:10.12.70.190
Oct 5 09:58:38.858: Sender:10.0.0.15 Pkt Loss:200(100%) Ehsr:0
Oct 5 09:58:39.814: IP MRM status report -- Test:prueba
Oct 5 09
Furthermore the time format is configured on the router in UTC+2 and the time show in the output is UTC.
Can anyone help me?
Thanks in advance.
Eduardo.
10-11-2007 10:26 AM
If the Test Receiver detects an error it sends an error report to the router configured as the Manager. The Manager immediately displays the error report. (The show ip mrm status-report command also displays error reports, if any.) You then troubleshoot your multicast environment as normal, perhaps using the mtrace command from the source to the Test Receiver. If the show ip mrm status-report command displays no error reports, the Test Receiver is receiving test packets without loss or duplicates from the Test Sender. Here is an example and explanation on each field in sh ip mrm status-report: More information is available at the following URL
