Lost CSA in tray after intsall and reboot
Oct 5th, 2007
Hello!
I make a new policy with rules Force VPN and Cisco VPN client policies.
After this I create group VPN FORCE and Windows Agent Kit with this group.
After installation on the windows client and reboot there in no CSA in tray...and there is no CSA in MCCSA also?
What could be a problem
Overall Rating: 5 (2 ratings)
tsteger1 Fri, 10/05/2007 - 07:23
  • Red, 2250 points or more
Either no Agent UI rule applied to the hosts or a rule that hides the UI and you won't see the little red flag.
Is there a rule that should keep it showing?
Tom
fisko Sun, 10/07/2007 - 22:50
I have 2 policies assigned to the group and 1 host assigned to that group. How can I check this Agent UI rule? Where should I find that?
THANKS FOR HELP!
tsteger1 Mon, 10/08/2007 - 08:22
Look at the host details and see if there is an Agent UI policy/rule module/rule assigned to it.
fisko Tue, 10/09/2007 - 23:32
THANKS MAN As soon as i add Agent UI i get the agent on client! THANKS!
tsteger1 Wed, 10/10/2007 - 09:16
You are quite welcome... have fun with it!
Tom
