Hardware VPN
Oct 5th, 2007
I have a few pieces of hardware which I plan to locate at a remote site. Are there any Cisco products which would enable me to have all of those devices on our network through a VPN. I do not want a dedicated line, but I would like the site to be on our corporate network.
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Fri, 10/05/2007 - 04:39
All cisco routers now have HW VPN. Juse depends on the circuit you will be using to the internet.
hope this helps, please rate post if it does!
dennis.graiani Fri, 10/05/2007 - 04:49
Does this mean it will act as a server, or a client. We have a VPN server at our main office but I would like to know if it is possible to have a hardware VPN "client"
Paolo Bevilacqua Fri, 10/05/2007 - 15:13
It can act as both. The best is to use a router also as "conecntrator", this way you can do the so called DMVPN and connect all your remote networks seamlessly. That can be as small as a 1801.
