ankbhasi Fri, 10/05/2007 - 04:59
  • Cisco Employee,
Hi Friend,
As per your profile you can move ahead like CCNP or CCIP but in general CCNP will be a good start which wuill give you exposure of some mroe details about routing switching and troubleshooting.
Ankur
ankbhasi Fri, 10/05/2007 - 05:29
  • Cisco Employee,
Hi Friend,
It depends in which domain you are currently working and the one which you are working most take it first so that you always remember the concepts in long run.
I myself preferred switching,routing, remote access and last troubleshooting because troubleshooting includes all routing,switching and remote access troubleshooting so once you have cleared all 3 , troubleshooting paper will be easy for you.
Ankur
Kevin Dorrell Fri, 10/05/2007 - 06:16
  • Green, 3000 points or more
I agree with Ankur on this. The troubleshooting is definitely the last one to take, because it relies on material in all the other three. What order to take the other three? I would say the strongest one first, because passing that will give you the confidence boost you need to tackle the others.
Good luck!
Kevin Dorrell
Luxembourg
