Archive Management on LMS
Oct 5th, 2007
I have scheduled a config backup using archive management in RME on LMS.
eventhough the credentials are correct, I am getting the following error on some devices
"Failed to fetch config using RCP.Connection timed out: connect Verify RCP is enabled or not. TFTP: Failed to fetch config using TFTP. Failed to get the start tag-! in the configuration.Check if the startup-config file is present on the device. "
can anyone help on this.
sathappan.s
David Stanford Fri, 10/05/2007 - 06:52
  • Cisco Employee,
Is this happening on any device in particular? (like a 4948G)
What version of RME are you running?
sathappan Fri, 10/05/2007 - 10:58
The Version of RME is 4.0.5
It is occuring on 10 devices out of 150 devices.(different type of devices)
sathappan.s
janvandek Fri, 03/27/2009 - 02:51
Last week we hit the same problem (LMS2.6 RME 4.0.6 on W2K3). Did someone found an answer on this ?
Thx
Jan
