Connect CME with PBX Huawei using MGCP protocol
Oct 5th, 2007
Is it possible to connect a Cisco Call Manager Express with a Huawei PBX by using protocol MGCP?
The design is as follows :
CME (SIP) <-IP Connection-> (SIP) VoiceGW (MGCP) <-IP Connection -> PBX Huawei(MGCP)
If possible, how to configure the VGateway?
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Fri, 10/05/2007 - 08:37
In the diagram above, CME only uses SIP, so yes that would be possible.
MGCP could be more complicated because the features are tailored to serve Cisco devices. it may work anyway.
connect101 Sun, 10/07/2007 - 23:43
Excuse me because it is not a PBX but a MSC Server (Mobile Softswitch Center).
If it's possible, would I configure my CME like I do it with a connection to a Call Manager Server, which using the MGCP?
Can you give me any idea
Best regards
Paolo Bevilacqua Mon, 10/08/2007 - 01:21
CME could work as MGCP endpoint to the MSC.
On the other hand, if you an higher level of integration, you should use SIP as I mentioned before.
