AnyConnect with ASA 8.02 not routing packets.
Oct 5th, 2007
I have the Anyconnect client successfully working in the sense that I am able to login successfully, the AnyConnect client shows that I have an IP address from the range that I have setup, but I am unable to ping, telnet, surf the web etc.
Do I need to setup an additional static statement for the range of IP addresses I'm using? or use a nat 0 statement? I"m using a publicly routable block of IP addresses and if I do a 'show route' on the PIX I am able to see the IP address show up in the route table.
Any help or suggestions would be appreciated. Thanks!
dbobeldyk Fri, 10/05/2007 - 07:38
BigPix# show vpn-sessiondb svc
Session Type: SVC
Username : denny Index : 7
Assigned IP : x.x.27.195 Public IP : y.y.y.y
Protocol : Clientless SSL-Tunnel DTLS-Tunnel
Encryption : RC4 AES128 Hashing : SHA1
Bytes Tx : 782727 Bytes Rx : 551731
Group Policy : DfltGrpPolicy Tunnel Group : DefaultWEBVPNGroup
Login Time : 11:38:50 EDT Fri Oct 5 2007
Duration : 0h:00m:10s
NAC Result : Unknown
VLAN Mapping : N/A VLAN : none
