Warning message
VRF on 3560 switch
Answered Question
Oct 5th, 2007
I have two 3560s connected via a Layer 3 portchannel. I have two vlans on switch A and one VLAN on switch B that i want to be in the same VRF. The rest of the VLANs on both switches i dont want in a VRF...
Im using OSPF for VRF and non VRF router advertisements...
how can i do this with an L3 link connecting the two switches?
TIA
Correct Answer by swaroop.potdar about 9 years 10 months ago
Shaun, you can do either of the options below.
1) Configure the L3 portchannel to L2 and have a vlan created for pure L3 between the switches and another vlan for the VRF.
2) If you dont want to configure it as a trunk then you can create a GRE tunnel between the switches and populate it with the VRF.
Both options would take care of switching you non VRF and VRF traffic.
HTH-Cheers,
Swaroop
Overall Rating: 4.5 (2 ratings)
Correct Answer
swaroop.potdar Fri, 10/05/2007 - 09:13
  • Blue, 1500 points or more
HTH-Cheers,
Swaroop
