3750G-12S-12 SFP support
Answered Question
Oct 5th, 2007
Hi - I'm trying to find out if the 3750G-12S-12 supports the GLC-GE-100FX SFP. I know there supported on the 3560's but can't find for sure if there supported on the 3750.
Any help would be great!
Brad
Correct Answer by ankbhasi about 9 years 5 months ago
Hi Brad,
Yes they are supported in 3750 switch but you need minimum 12.2(20)SE and later to get this sfp module working in 3750 switch.
http://www.cisco.com/en/US/customer/products/hw/switches/ps5023/products_qanda_item09186a00801b0971.shtml
Use this link and chck the section "What SFPs are supported on Cisco Catalyst 3750 Series Switches"
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Fri, 10/05/2007 - 08:18
  • Cisco Employee,
Hi Brad,
Ankur
