Cisco 1300
Oct 5th, 2007
I've used the tftpd32 application in the past to configure the Cisco 1232 AP's with an IP Address, can someone tell me if that tool works on the Cisco 1300 Bridge as well. All I want to do is put an IP address on the bridge so I can go into the GUI interface thru Windows IE. I'm not comfortable with the CLI and using HyperTerm
Thanks for the help.
Jagdeep Gambhir Fri, 10/05/2007 - 11:52
Yes, you can use it with Cisco1300 Bridge.
Please rate helpful posts
lonnylegrand99 Fri, 10/05/2007 - 12:21
So just plug the 1300 into the Power Injector, the rj45 cable from the Power Injector into a hub or directly to the ethernet port on a laptop or desktop or does that still have to go thru a hub.
