Blackberry with Unity Connection
Answered Question
Oct 5th, 2007
Has blackberry support been added with Unity Connection? Customer has IMAP for their Outlook express client, and wanting to retrieve the voice messages from Unity Connection as well as their mail on blackberry.
thanks
Correct Answer by Rob Huffman about 9 years 8 months ago
Hi Daniel,
Hope all is well with you. Sadly this is not supported yet :( Here is the latest and greatest Comparison doc;
Cisco Unified Messaging Feature Comparison
Version 2.0 Updated August 30, 2007
http://www.cisco.com/en/US/products/ps6509/products_data_sheet0900aecd806bfc37.html
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Fri, 10/05/2007 - 10:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Daniel,
Hope this helps!
Rob
SBCdd7343 Sat, 10/06/2007 - 04:41
Hi Rob,
Our friends at Cisco informed me that while there is not true Blackberry support, Unity Connection will email the blackberry letting the user know that a voice mail is waiting in UC inbox. Then user just has to press a digit to callback UC inbox to retrieve.
This is acceptable to my customer, so all is well.
As always, thanks for your quick response.
Daniel
Rob Huffman Sat, 10/06/2007 - 07:27
  • Hall of Fame,
    Founding Member
Hi Daniel,
Thanks for posting back with this info. This seems like a reasonable solution doesn't it! 5 points for sharing this info for others who have the same question. Good work!
Take care,
Rob
mknepper Thu, 12/11/2008 - 13:57
Any further progress on this with v7? Can the BES server connect to the IMAP connection and provide the message to the Blackberry?
Mark
Rob Huffman Fri, 12/12/2008 - 07:20
  • Hall of Fame,
    Founding Member
Hi Mark,
I believe there is a significant improvement coming in UC 7.1 You should talk to your Cisco SE about the feature set for 7.1 which will start EFT in early January. I don't think these can be discussed here due to the NDA.
Hope this helps!
Rob
