ppp not supported on vwic 2mft-t1
Oct 5th, 2007
I have a 2821 router with a vwic 2mft-t1 card. When i use the ip base w/o crypt ios i can set encapsulation ppp on the serial interface. when i use the ip base ios and try to set encapsulation ppp on the serial interface i get the message that hardware does not support the encapsulation?
royalblues Sat, 10/06/2007 - 00:56
  • Green, 3000 points or more
What Major IOS release are you using?
As per feature navigator, PPP is supported on the 2821 with ip base feature set in all major releases of 12.4
Narayan
mnight Sat, 10/06/2007 - 07:29
I have tried this with two files:
c2800nm-ipbasek9-mz.124-13.bin
c2800nm-ipbasek9-mz.124-17.bin
Both give me the same error message.
Thank you
Mike
paolo bevilacqua Sat, 10/06/2007 - 08:09
  • Hall of Fame,
    Founding Member
very strange. If you can prove this to the TAC and they can reproduce, should be a new bug if not known already.
