Interconnection between two 3550 WS-C3550-48 switches
Oct 6th, 2007
Hello
please anyone can give me a hint how to interconnect two 3550 WS-C3550-48-EMI switches together by the Lan port? (not the fiber optic cable using the GBIC)
i have tried to connect a cross Cat6e cable between both but no connection is established between them. is there any command or something?
Jon Marshall Sat, 10/06/2007 - 04:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
No, a crossover cable should do it. Can you check the duplex and speed settings of the relevant ports.
Also is this the only connection between the 2 switches, as if there is already a connection then STP might be blocking this link.
Jon
Jagdeep Gambhir Sat, 10/06/2007 - 04:24
  • Red, 2250 points or more
In addition to what Jon said I would like you to check the status of link light i.e. if it is amber or no light at all ?
If amber then issue could be speed/duplex , port settings (access or trunk port), STP , DTP neig.
If there is no link at all then check if port is in shutdown state, make sure CAT cable or port is not bad.
Hope that helps !
~JG
Please rate helpful posts
akobeissi Sat, 10/06/2007 - 04:30
thank all you for your reply,
ill come back to you soon after checking the ports settings.
