RATE limit RATE limit RATE limit RATE limit
Oct 6th, 2007
Dear,
I have tried using RADIUS server to apply rate-limit to my ADSL coustomers using :
rate-limit output access-group 101 1024000 6000 512000 conform-action transmit exceed-action drop
i applied this at raduis server at my output interface but i does not work.
there is no output for sh interface rate limit.
the configuration and settings for rate limit are applied at raduis server....ok
when i do sh interface rate limit on router....i dont have any results.
i have configured (VPDN interface-Virtual and interface-access ) for my ADSL coustomers.
i need to make bills for this customrs.
please if the points not clear let me know
wdrootz Thu, 10/11/2007 - 13:44
Try this configuration in your interface , or write the access list depend upon your requirement and implement it.
access-list 152 permit tcp any host eq www
access-list 153 permit tcp any host eq www established
interface {int}
rate-limit output access-group 153 1024000 6000 512000
rate-limit output access-group 152 1024000 6000 512000
finally verifies this configuration through the following commands.
show access-lists rate-limit
Displays information about rate-limit access lists.
show interfaces rate-limit
Displays information about CAR for a specified interface
I guess you have to apply this on the radius only and not only the physical interface. When the session estblished the rate limit settings will be downloded to the particular virtual-access interface.
Take a look at this link for the radius config:
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800b2d29.shtml
When the session established you can check it issuing the show interface virtual-access x rate-limit
Hope it helps, rate if does
Krisztian
