mpls,vpls and ES20G module for 7600
Oct 6th, 2007
hi all,
do i need a ES20G module on my 7600 in order to perform VPLS,6VPE mpls and so on...
is this module just a 'speeding' module for these fonctionnalities ?
(it is very expensive and the license too)
Can i implement these features without it ??
Does someone use vpls on 7600 without that module ?
Thanks for answer
Overall Rating: 5 (2 ratings)
swaroop.potdar Mon, 10/08/2007 - 08:56
Yes you can run VPLS without ES-20 using any WAN OSM or SIP-600 faing the core.
Although there would be cost difference in each module including ES-20G, but these modules have been designed with different objectives and requirements in mind. As each module provides you with either a certain media type density(ES-20G) or OSM , or the flexibility of media type usage etc (SIP-600).
So you can weigh the pros and cons with each module including the cost marked to the budget and take a call.
rrooney Mon, 10/08/2007 - 08:58
The ES20 comes in two flavors - 20 1 gig interfaces or 2 10 gig interfaces. The only cards that support VPLS are the SIP-400, SIP-600, OSM, and ES20. These cards would be required on the PE-P link but not in the core.
I agree - very expensive card and the stupid advanced sw license on top of the already paid for ios license is just ridiculous.
