STUN or UDPTN
Oct 6th, 2007
I would like to serial data (V.35 and RS232) over a lease line, but can STUN or UDPTN use for the connection below?
DTE -> V.35 cable -> WIC-2A/S -> Router 2801 -> WIC-1T -> lease line -> WIC-1T -> Router 2801 -> WIC-2A/S -> V.35 cable -> DTE
If not, what method can use for this kind of setup? CEoIP?
paolo bevilacqua Sat, 10/06/2007 - 10:23
  • Hall of Fame,
    Founding Member
If the DTEs are using HDLC, stun should work. What are these DTE?
weiliang82 Tue, 10/09/2007 - 22:52
I have checked with the end user, they told me that the DTE is some kind of computer which support X.25 protocol. I done a quick check on this, and found out that X.25 can be route by using command XOT. Is it true?
