PPTP Issue
Oct 6th, 2007
I want inside users to be able to establish VPN session with VPN SErver on the INTERNET.....
users connect using Microsoft VPN Client (PPTP )
The required ports PPTP is opened but still cannot establish connection...
It hangs on verification for users and password....
If the Same user tries VPN connection using an ISP dial-up account it works fine....
Do I need to open some-more ports on PIX 515....
Thanks Mate in advance.
Fernando_Meza Sat, 10/06/2007 - 12:06
Hi ...
make sure you have the below entry on your config.
fixup protocol pptp 1723 (on version 6.X)
inspect pptp (on version 7.X)
I hope it helps .. please rate it if it does !!!
