SRST and CCM 5
Oct 6th, 2007
  • Bronze, 100 points or more
Here is a strange one. Doing a cutover from 4.x (Old server) to a Pub and Sub 5.1 system. everything works well except for srst.
the phone comes up with the active and standby as well as the srst but if i fail the WAN nothing happens. just stays at registering.
now if i put them back on the old ccm it works properly.
changes i have made are as follows:
ccm-manager config server <to new ip>
all other configs remain the same
call-manager-fallback
max-conferences 6 gain -6
transfer-system local-consult
limit-dn 7910 1
limit-dn 7940 2
limit-dn 7960 2
ip source-address <ethernet> port 2000 strict-match
max-ephones 20
max-dn 20
system message primary Main link down
dialplan-pattern 1 31.. extension-length 4 extension-pattern 31..
keepalive 10
default-destination 3160
access-code fxo 9
any ideas?
Chris Deren Sun, 10/07/2007 - 09:56
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
is for your MGCP config and does not matter here.
did you change the:
ip source-address port 2000 strict-match
Do you have the SRST referece defined on CM? Is it associated with the proper Device Pool?
Chris
a.gooding Sun, 10/07/2007 - 19:30
the ip-source address remained the same - local ethernet ip. this was there before. i have defined 4 device pools for my 4 locations and in my srst i put to use each location. i have also defined my srst reference to point to the IP i had configured on the old system. Now all phones are 7912-A. would firmware be an issue here?.
a.gooding Mon, 10/08/2007 - 11:32
Any suggestions on this one.?
