DIALER TRIGGERS ABNORMALLY!!!!!!!!!
Oct 6th, 2007
In what circumstances will a dialer triggers even if it is in shutdown mode?
CONFIGURATION BELOW
interface Dialer3
description ISDN Backup NO: site 1
bandwidth 128
ip address 10.1.1.1 255.255.255.252
ip rip authentication mode md5
ip rip authentication key-chain RIP_KEY
encapsulation ppp
shutdown
dialer pool 3
dialer remote-name remoterouter
dialer idle-timeout 300
dialer string 111122222
dialer hold-queue 100
dialer-group 3
fair-queue 64 512 3
no cdp enable
ppp authentication chap
ppp chap hostname BahrainISDN
ppp chap password ourpassword
ppp multilink
ppp multilink links minimum 2
sh ip int brief
Dialer1 10.127.254.250 YES TFTP up up
Dialer2 10.127.254.254 YES NVRAM up up
Dialer3 10.127.254.246 YES NVRAM standby mode/disabled down
Dialer5 10.127.254.234 YES NVRAM up up
Richard Burts Sun, 10/07/2007 - 08:02
Celso
Are you sure that it is dialer 3 that is activating? With the dialer in shutdown I can not see a way that it would be dialing. If there are 3 other dialers that are up up, is it possible that one of them is activating? I would suggest that you run debug dialer and post the output from it on the next time that the router activates its dialing interface.
Rick
